Hi Nigel
Can you quote on the following please
Front Brake Discs
Rear Break Discs
Front Brake Pads
Rear Brake Pads
Front Sensor
Rear Sensor
My Reg is N100EEE
I have had a quick read and i think there are two different sizes is there an easy way to tell what type i have or will i need to take the wheel off and measure?
Regards Nick
Hi Nick,
It's best to whip the wheel off and double check, but it's comes up with 300mm fronts and 294mm rears,
Fronts £46.92 or slotted for £61.53
Rears £45.09 or slotted for £60.07
Front pads £19.87
Rear pads £21.24
Sensors front £8.97 rear £11.63
Nigel
Hi Nigel
I just checked and yes they are 300mm fronts and 294mm rears. What are the difference between the slotted and normal ones? How do I place the order?
Regards Nick
