please could anyone tell me where to find the alarm siren on a 2003 330d , just stopped working but indicators still flash so just the siren but where is it ?????
Moderator
Remove the pollen filter and remove its housing(4 torx head bolts)then you may be able to see it at either side of the blower box close to the bulkhead,if not then you need to remove the panel directly in front of the blower box.
This is all done from the engine bay.This will give you a good idea http://e46fanatics.com/faq/alarminstall/
You sure it hasnt been programmed to just flash
Mine will siren for 30 seconds appox then continue flashing no sound i think this is normal if yours is flashing its obviously still working just the audible horn part might have failed
