On depression of the clutch pedal there is a noise like a dry bearing, presumably this is the thrust bearing. The noise stops as soon as pressure is lifted a slight amount from the clutch pedal, but I suspect that although the clutch works properly with no indication of slip it is on the way out at 175000 kms. The only choice for me in this part of the world is the main dealer, does anyone know of the cost of clutch replacement for a 325xi? just so that I have my heart attack in stages! Thanks,Are
