1 - 1 of 1 Posts
The fuse for the sunroof #46 which is 30 amps keeps blowing with the roof 95% closed. You do not have to touch the switch to blow the new fuse. I checked the sunroof switch on a multi-meter and the switch is fine. The wiring in to the motor seems fine. How do I tell if it is a bad motor or would it be something else like a short to ground?
1 - 1 of 1 Posts
