Hi . . I'm currently part way through changing an engine in a 1995 M 318i SE single cam 8v .. .the donor engine is the same but from a 1998 car that had a rear shunt . . i'm all but finished apart from finding a home for one of the 2 pin push on plugs with a blue rubber gasket inside from the centeral wiring harness .
I have looked on autodata at engine management component locations but it always seems to show a twin cam engine in the picture and the same happens when my local garage looks it up aswell ..
Was just hoping someone here might have some information which could help me find a home for the last plug!! . .
Any help would be greatly appreciated. .
Is it the crankshaft sensor on cam sensor where they connect under the manifold, maybe?
Thanks for ur quick reply i have the two knock sensors and the other two sensors on the top of the block under the inlet manifold if thats the one you mean . . i will look again tomorrow and try to list what i do hava connected and maybe take a photo or 2 . .Thanks for all ur replys peeple
found a home for it . .. will post diagram with all connections labled later so if anyone else has this problem its there!
Excellent news, do tell :thumbsup I had a look on Autodata and the 318i M43 is definitely listed for a 1998 :thumbsup
Will come up 16 valve if you select "318is" though :hihi
