Hi all
Plugged my Carista into my mate's 2015 F30 318D today and it came up with fault codes.
I did this as it won't turn over when he turns the key, just makes a click sound. He changed the starter motor today but it hasn't fixed the problem.
Can someone pinpoint from this list of codes what the possible problem is please? Or where I can find the codes on a list? I've tried everywhere!
Heater & air conditioning:
8011F9 - PTC right: internal fault detected in PTC
8011FA
801237 - IHKA: right type of climate selector wheel: short to ground
E71430
Airbags:
930BB9
Dynamic management:
480134 - ICM: direction of travel cannot be determined
Front electronics module (FEM):
804080
8040B5
8040B7
8040B9 - Deactivation of terminal 30B: top startability limit reached
8040BB
8040BD - Terminal 30F reset or deactivated
8041A8 - Welcome lights repeat interlock active
80444D
Rear electronics module (REM):
8031D9
Center roof module:
801A55 - FZD: deactivation due to overtemperature
Infotainment system:
B7F805
B7F809
B7F85A
B7F8CD
CAN network gateway:
CD0420
CD0487 - CAN gateway: synchronization process for FlexRay failed
What is the condition of the battery like?
Also can you hear the fuel pump prime when car is unlocked?
He's going to do a load test on the battery in the morning and test it with a multimeter. So as he unlocks the car, you should hear the fuel pump??
Good starting point
Yes you should hear it prime up when you unlock or open drivers door
I'd guess he charged the battery up, it worked, he didn't reply!
Same happens all the time on my landrover, very poorly battery so if I leave it a week it's dead. If I run it for a few minutes every few days it's fine!
