Hi guys an gals. Long story short over the past year on and off AV been doing a engine swap in my 1997 316 compact with a 1997 328 engine.
Got the engine form a breakers. Engine is in just need a few other bits to finish off.
Ok I got the ews flashed off the ecu so hopeing that wouldn't be a problem. Am keeping the battery in the engine bay and I have moved all the power wires over and just conntected them all to the + on the battery. Battery needs charged up but the car turns over. But I can't hear the pump working and the oil light and abs light stay on all the time even with the key out. The fuel lines are off but no fuel is comeing out when I turn the engine over. Any help of ideas
Just done a engine swap done,316it N42- to 525i M54 b.. picks posted soon..for the 328 swap use the loom,EWS,ECU,KEY BARREL.. or you will be scratching your head for a good while. Also there's pipe work/water/power steering/heater return/ good luck..
