1 - 10 of 10 Posts
Hi,
Just picked up an F15 X5 25d 2015.
Car came with a 2 yr BMW warranty.
I would like to remap to improve BHP and also economy.
Is a remap visible to BMW?
David
Super Moderator
short version all remaps are visable regardless of what tuners may say depends if the dealer checks but these days most dealers check first thing for remap evidence with engine warranty work......
Yes and it will almost certainly invalidate your warranty.
BMW probably offer a performance upgrade if you want to go down that path.
Vendor
May other tuners will say it’s not detectable
And it all depends on which way they mean
If a bmw tech drives the car and looks at the live readings then he will see it’s been tuned
Some tuners turn the tuning protection codes off or set the programming data as it was before it was touched so the diagnostics with not flag it’s been tuned but the if the tech does the above he will see it is
We are honest if your worried about warranty then wait till it’s run out before remapping it
There are so many dishonest tuners out there as I’ve found out from the work they have dose to customers car who came in for me to fix them
BW chiptune
Tuning BMWs since 1991
Dyno Dynamics rolling road.
BW autorepairs
Over 30 year repairing BMWs.
New and fully refurbished BMW/Alpina ,Ecus (DME,DDE)and Cas units.
BMW Ecu repairs.
Key data fixed for non starters or when theft attempted.
UK
0208 561 1818
07831 103030
Hayes
UB3 1BB
or
Spain
Orihuela Costa
+447831103030
Vendor
Tuning Box is the only way for warranty issues.
I use VenturaTuning powerbox and is a 2018 F30 330e, now with 314Hp.
Each time I have a service I remove it and install again. When removed goes back to OM Settings, so no trace.
It’s Plug&Play , 4 connectors and easy.Or gosto a car shop, 5 minutes.
It will get 275Hp or 260Hp depends if is the xdrive or not.
Enviado do meu iPhone usando o Tapatalk
Modern day ECUs keep logs even if a diesel box has been fitted if you look deep enough
Also tuning boxes don’t make the power they claim
If you really need to tune your car it’s best to remap it then before you take the car in to a dealers put the ecu back to standard
BW chiptune
BW autorepairs
BMW Ecu repairs.
UK
0208 561 1818
07831 103030
Unit 8&9
alpha industrial estate
Clayton Rd
Hayes
Middlesex
UB3 1BB
or
Spain
Orihuela Costa
+447831103030
Vendor
all your posts are to Advertise these diesel tuning boxes
Vendor
For me the best tuning boxes are Ventura and AC Schnitzer.
the majority of fóruns they only talk about remapping and never talk about a lot of problems that can happen doing that
If a car is Remaped correctly by a good tuner who knows what they are doing then there will be no problems
Now what about all the problems boxes cause and the fact they don’t make the power they say
As well and not showing the before dyno readings only claimed power output
Vendor
I have a honest dyno dynamics rolling road and I have tested many diesel tuning boxes that have been over £350
I also specialise in bmw ECUs as well as fixing the problems with tuned bmws
Vendor
Yes I know all about race chip
Since you joined 2 days ago all the bmw forums all your posts are to Advertise these Ventura diesel tuning boxes
And I’ve seen the same types of post under different user names on may other forums which are being spammed
1 - 10 of 10 Posts
