Anyone out there suffering same issues as me jerky gear shifting up and down its like been in a manual but yanking clutch out any ideas or thoughts to a solution thanks?
I'd get the fluid level checked - hard shifting is often caused by low fluid levels so you may have a leak somewhere.
Gearbox specialist or worst case, main dealer. There's no dip stick so it's not DIY.
You could also check for any leaks (remove undertrays, torch, and have a good check round the sump etc.
