I am experiencing issues with my offside parking light and would like advice some advice before I go down the more expensive route.
At this time when the sidelights are switched on the ns works fine and the os does not light. I checked with a multimeter there is no voltage coming to the bulb.
Please note, before this failed I was getting failure/clear/failure/clear and the bulb was flickering until it stopped working normally.
I would appreciate any advise and thank you in advance and apologise if this has already been covered in another post
Thank you Can man:
Bulb - works fine in the nearside holder
Wires - Checked the cables leading to the bulb holder - no obvious breaks, wire feels smooth, not trapped.
Fuses - 40 and 57 checked in the front and are both OK - not had chance to check the rear fuses (should they need checking)
I checked the wiring diagram which unsurprisingly is not much use and all roads lead to Rome, well one of the ECUs.
Could this need a simple error reset?
Got it checked out today when in for its oil service. The wiring near the os wheel arch is significantly corroded/damaged and lucky to only have 1 light out by the looks of it (what a great design........) so is being replaced.
Thank you all
