2013 F10 Front Position Lamp
1.4K views 20 replies 3 participants last post by  marcsadams
No I don’t think the DRL is replaceable DIY, someone might say otherwise though.
Modules need coding they won’t be plug and play as there’s different lamp configurations.
You could try swapping module side to side just to see if DRL works?
With mine I gave the terminals a good clean/scrape with small terminal screwdriver and a sewing needle to remove as much as possible and used plenty of electrical cleaner.
Mine was only nearside that had moisture in, I took lamp out to run some clear rtv round the joint so cleaned up while it was out.
Small smear of dielectric grease on plug and I got lucky as issues resolved and did not come back
