Bad relay likely, I don't know much about 2007 onwards.
If you can find the relay location using google and see if there is another relay on the car, use the known working relay in the window washers spot to test. If it works, buy relay off ebay.
BMW 3 Series Forum - Technical Talk on the BMW E46
Hi guys, i'm posting this thread on behalf of my mate paul (i've tried convincing him to sign up but he can't even check his e-mail...)
He's recently purchased an e46 330d touring (after finally getting rid of his p38 2.5 DSE range rover:)) and it has a problem where after 5 or so minutes of...
Hi
Had this before but today I wonder out of curiosity, why is it the case that when I open the car via key fob, as its iced up the actuator does not raise, when I go to open the door the alarm sounds?
I would have thought if you used the remote fob the car would be expecting the owners to...
Over the course of the past year, several things have gradually stopped working. For example; it started with the clock resetting itself each time I started the car, followed by the trip counter. Then the stereo stopped working. Some of the functions such as the seat belt audio sound have...
Hi all
I am going to change my tired starter motor, so am asking for advise on getting to it.
Having rummaged around underneath the car removing plastic covers and not being able to even see it, I assume it's done from above after removing the inlet manifold? I want to remove the manifold to...
Couple of questions
When undoing the head bolts the bolt at the back left next to exhaust manifold was completely loose not broken just loose which is where the gasket was leaking all the rest were tight any ideas why that particular bolt was undone? I have never seen anything quite like it.(I...
