hi all got a 2009 520d e60 went to open the passenger door and it wont open inside or out button is going up and down with the remote, i manage to push the door panel back a bit to see down and pushed the lever with a bar but it still wont open any ideas much appreciated
My money would be on the bowden cable failing. Sometimes they break or the tab on the end falls off. If this is the case then you will need to get the inner door trim panel at least partially free so you can get at the latch release.
You really need the door open to get the trim off completely. I strongly recommend getting hold a set of plastic trim tools. Cost you a couple of quid and can save you a fortune in broken tabs and clips.
