Hello all,
My 2007 E90 320d is now at around 150k KM's, and never did the diff oil change. So, I changed that.
Afterwards, I noticed a very small leak around the drain plug.
So, I bought a new plug (plug + O-ring combo) from eBay. The new plug, not sure if OEM or not, came with a new green O-ring.
I put the new one in, but, discovered that it still leaked a little.... Now what? I did tighten it down to 60 Nm.
So, what should I do? I considered changing the O-Ring that came with the plug, not sure the correct size...
The size of the O-Ring is not found anywhere (RealOEM did not have a seperate O-Ring part #)
I did measure it myself, and it seems to be 22mm x 1.5mm O-Ring......
Here's the before and after (about 10 days apart).
Right after replacing it with a eBay-bought new plug, tightening down to 60 Nm, and cleaned with brake-clean:
And, about 10 days later (mild city/highway driving).
How much oil did you put in as i went to do mine not long ago and found no drain plug just the fill plug.
Just topped mine up for now but not leaking.
There is no separate drain plug on these E90 diff's. You have to somehow suction out the oil inside, then fill until it runs out. I think I used nearly the whole 1 Litre bottle. RED LINE 75W90 GL-5 GEAR OIL to be exact.
The diff capacity is 1 litre, so I'd say you were spot on. And frankly I can't see anything I would call a 'leak' in your photos. Just enjoy!
Are these not the signs of leaking?
Could this just be the residue oil from the installation process?
(Like, minor oil from under the cap?)
That's a relief if that's not an actually oil leak.
BIG THANKS!
