Recently purchased an 07 plate, E61 525i Sport Touring, with 40k on the clock. Tyres initially looked fine. However, the car had a faint whirring noise reminscent of a wheel bearing going at speeds of 60mph and above. Wasnt too bothered as the car still has over a year BMW warranty to run.
This noise gradually got worse and worse over the course of 300 miles or so, until it was there at all speeds, loudest at around 25mph especially when coasting without throttle.
Took the car to BMW dealer who agreed that one of the front wheel bearings appeared to be faulty, was unable to pin point exactly which one though. They also noticed a tiny bulge in the front nearside tyre. (Goodyear NCT5 245/40 18's runflats all round). Booked the car in to have both the bearings looked at and decided to change the front tyres due to the bulge.
Best deal was with etyres.co.uk, lowest price I could find and they come to your home to fit.
The tyre fitter commented that, apart from the bulge, both the front tyres were close to being illegal due excessive wear on the innner edges. The remainder of the tread was fine at over 5mm. So, new Goodyear NCT5's were fitted.
Low and behold, on taking the car out for it's first run on the virgin tyres the bearing noise was completely gone! MAGIC ??? .... Not quite ....
Since then have added another 100miles or so and the whirring bearing type noise is definitely starting to return, though not yet as loud as before the tyres were changed.
My questions from all this are ....
Is it normal for these expensive runflat tyres to wear so badly on the inner edges?
Is it likely that in raising the car using a trolley jack, something was moved in the front suspension that stopped the bearing noise for a short while, at least until the suspension settled down again?
Is it possible the faulty bulging tyre was the cause of the noise?
Has anyone else had a similar experience?
Car is booked to go into the dealer next friday, with a bit of luck the new tyres will last until then! Will have a 4 wheel alignment done whilst it is in to hopefully stave of the wear bug!
Would welcome any and all inputs from you more experience BMW owners to understand this issue better. I am not sure how old the original tyres were, but judging by the overall wear not very.
