Hi everyone,
2 months ago I bought a 2nd hand 120 series 1. Last Thursday on the M62, the engine mgt light came on, the car went into limp mode, and I realised that it was on fire!. Managed to get onto the hard shoulder, tried to stop but no brakes. Used the hand brake to stop, and the car caught fire and subsequently burnt right out. The entire front has gone, with only the boot intact. Im waiting for BMW to get back to me, but does anyone have any ideas what might have caused this. Loved the car and want to get another, but ......
Cheers for any response.
Thanks.
Super Moderator
Sounds like N47 engine and failed EGR bypass valve. Melted intake manifold and then caught fire. Not the first and not the last.
I agree and this is typical of the egr recall and is not the first to go up in flames. Pleased you got out safely which ultimately is the most important factor.
Jim
Vendor
It’s the parts company bmw use as the will use the cheapest they can
These EGRs on the n47 wears a dip in the metal as the metal is not heat tread and is very soft
The egr then gets stuck open
All the ones we have programmed to stay shut from many years ago have not had any problems
BW chiptune
Tuning BMWs since 1991
Dyno Dynamics rolling road.
BW autorepairs
Over 30 year repairing BMWs.
New and fully refurbished BMW/Alpina ,Ecus (DME,DDE)and Cas units.
BMW Ecu repairs.
Key data fixed for non starters or when theft attempted.
UK
0208 561 1818
07831 103030
Hayes
UB3 1BB
or
Spain
Orihuela Costa
+447831103030
Thanks for your reply. Tried BMW but no response.
Looking at a 2008 series 1, would that have the same engine?.
Vendor
They never respond unless it’s we have never seen or had this ever
