1 - 1 of 1 Posts
Hi I need to remove the turbo from my 530d E60 Lci, Could someone who has done the job before advise what other items need removing in order to get the turbo out through the bottom? I understand the alloy strengthening plate and the DPF need removing, but what about the steering shaft or the engine mount? The turbo is clamped to the manifold and not bolted through the airbox as are the earlier ones, there is clear access to the clamp bolt.
1 - 1 of 1 Posts
