1 - 8 of 8 Posts
my car started to vibrate slightly under braking so I thought I may have lost some weights off the wheels, the next day going to work the vibration turned in to a judder making me thinking a defect tyre, had a quick look nothing found got to work sat but then later in the day when I was returning home the juddering was getting worse under braking I could see the steering wheel vibrate, managed to limp home slowly (everywhere was closed sat afternoon).
Took both front wheels off to see if there was anything I could notice, just looking did not reveal anything, I am now thinking it could be a shock failed? I am a keen DIY on my car but no expert. can anyone shed any light on the issue before I book it in on Monday please.
Thanks for reading
Thanks for reading
Most likely your discs need replacing. I have the same issue.... quite violent at high speeds. Happens when the discs are warped.
Mine is a violent judder at low speeds, did not dare drive faster whilst it was happening, I did stop and touch wheels hub and caliper and they did not seem hotter then normal, I am about to change the lower suspension arms and see what happens.
Experts said more likely the front upper suspension arms, so as I had time changed them and the front lower, same?? changed the discs and now fine
You are saying that you changed the discs and now it brakes fine?
Enviado desde mi Pixel XL mediante Tapatalk
I had same problem, mainly when braking slightly harder than normal, violent judder, I had a new lower arm fitted and problem cured at 60 and under but still a slight vibration at higher speeds when I step on brakes hard but nothing like it was, not sure if discs are warped or upper arm is on way out
1 - 8 of 8 Posts
