Have seen the price on your website for Apex spring kit. Is that for all 4 corners?
I am also on the lookout for drilled and grooved discs front and rear. Can you help?
Hi Mate,
yes that will be all four corners, I can supply the drilled grooved discs, please check your disc diameters as the quote is for the bigger discs,
Front 324mm £88.96
Rear 320mm £70.17
Hi Mate,
Front 324mm £88.96
Rear 320mm £70.17
Cheers for that. got the discs and pads from you just over a month back anyway but im still wondering about the suspension though. Easy to fit as a DIY job?
