1 - 9 of 9 Posts
Hi i have swapped all 6 injectors on my 6 cylinder 3 litre X5 every thing has been built back up to original speck and there is fuel at the injectors but it just wont fire over does anyone have any ideas of what it could be all the injectors are new and genuine as i bought them from BMW direct
Super Moderator
Quite difficult to say without trouble codes. Have you tried with easy start or brake cleaner sprayed into intake?
Vendor
If it doesn’t start on easy start etc
Then there maybe a compression leak
Can you hear a leak by the injectors when cranking
Did you fit new injector sealing rings which can from the dealers as I’ve seen aftermarket ones that have been thinner
Did you check where these copper seal rings sit in the head was clean
BW chiptune
-Tuning BMWs since 1991
-Dyno Dynamics rolling road.
BW autorepairs
-Over 30 year repairing BMWs.
-BMW Ecu repairs.
UK
0208 561 1818
07831 103030
Unit 8&9
alpha industrial estate
Clayton Rd
Hayes
Middlesex
UB3 1BB
or
Spain
Orihuela Costa
+34643890040
+447831103030
BW chiptune
BW autorepairs
-BMW Ecu repairs.
UK
0208 561 1818
07831 103030
Unit 8&9
Clayton Rd
Hayes
Middlesex
UB3 1BB
or
Spain
Orihuela Costa
+34643890040
+447831103030
Yes I have done all that even cleaned all the injector seats its literally as if the injectors arnt firing I have read that trying to use a hand pump as the cranking power of the starter cant build up the pressure in the rail it's the same on Volvo's and Fords but I wanted to know if some knew something ?
Super Moderator
This can be caused by lost EWS-DDE sync preventing injection. It doesn't always show on codes. This is why I asked what software you have for diagnostics.
Assuming it is not a diesel have you checked for spark at any of the plugs cause if you do have spark then it has to start with easy start spray(it’ll sputter a lot but it will start)and if it doesn't have spark(which I believe is the problem you are having)then you would have to check each coil individually if none of them have spark then you might have a bad timing sensor also referred to as a crankshaft or camshaft position sensor. Worst case scenario you may have a bad ecm(engine control module)
1 - 9 of 9 Posts
