Since wednesday, there is hardly any acceleration when the rpm is a bit below 1.5 and when it comes to about 1.7 it starts accelarating (normaly) - I don't think this is normal as it didn't happen before.... any ideas what might be wrong?
The first port of call should be getting the fault codes read for the cars ECU(s), any Main dealer(more expensive), BMW Independent specialist or good independent garage should be able to do this for you, get a copy of the codes and then post them up here and we will help out where we can with what you need to do next.
Initially first thoughts are it could be due to a air leak on the engine induction, vacuum or breather system.
