1 - 1 of 1 Posts
Hi does anybody have any experience with these two codes
Fault Code: 005DC3
Fault Explanation: :Rear wheel speed sensor Right Start detection (comparison) / Yaw-rate sensor: Internal error PSIP2SensNotAvailable (DRS-type MM3.x) / Yaw-rate sensor: Internal error. PSIP2SensNotAvailable. (DRS-type MM3.x) / Speed sensor, rear right detecting starting v comparison / Speed sensor, rear right detecting starting v comparison. / Incorrect wheel speed sensor, rear right / Yaw- rate sensor: Internal error. . PSIP2SensNotAvailable (DRS-type MM3.x --- (DSC: DSC sensor internal)
Fault Code: 005DB3
Fault Explanation: :Speed sensor, rear left detecting starting v comparison / Lateral acceleration sensor calibration error missing / Wheel speed sensor rear left start up detection (comparison) / Inlet valve (EV) Back Right: Error cyclic relay valve and test --- (DSC: control valve actuation device) / Inlet valve (EV) Back Right: Error cyclic valve and relay test. / Speed sensor, rear left detecting starting v comparison. / Inlet valve (EV) Back Right - Error cyclic valve and relay test.
I have no speedo erratic fuel gauge and no mpg needle movement
When the car is started I have the trifecta lights on in yellow when I move off handbrake light turns red then the seatbelt light and airbag light come on
Any experts out there your guidance is what I need please
Also is there anybody in Preston who can update the idrive
1 - 1 of 1 Posts
