hi could someone help i have a e90 with the none smoking pack.where can i get the power from for my tomtom.(power in the boot also inop).regards peter.
In that case it sound like you have a blown fuse. I'd check that first.
(You are of course aware that the socket only gets power after the engine has started)
That said, the armrest power socket isn't very practical for powering something to be used on the dash. I fitted an expansion socket i the passenger foot well, which draws power from the wires going into the socket in the armrest. Its easy to root the wire under the center console.
The best place I found was the obd socket, and it's in the area you want to go but you need to check for just ignition on 12v, hope this helps.
Went into bmw today saw one of the lads total bill 55p fuse.Thank you all for your replys.
