Hi All,
About 3 months ago I bought my first BMW, a 2005 320D SE E90. After filling the car full of diesel for the last time, I park the car on the drive and forget about it. About an hour late I go outside and theres a pool of diesel under the rear drivers side whell. I take the car back to the garage I bought it from to be informed this was a common fault on BMS's - apparantly the "seals" can go which results in diesel leaking. Anyway, they "apparantly" change the seals and it's been fine - up until this evening, when again I fill the car diesel - only to go outside an hour later to find another pool of fuel under the car - same place as last time so I'm guessing it's the same problem. I've taken care not to over fill the car as I was told this could cause this type of problem??? Anyway, any ideas why this keeps happening? Is this really a common fault on this model? And any ideas to a solution???
Thanks a lot
J
Thanks a lot
J
