1 - 8 of 8 Posts
Hi Guys,
I have read various threads on the Net that suggest the X3 (from 2005 on) may have been pre-wired for Bluetooth, even if the car wasn't factory fitted with it. Admittedly these threads are US based, so it may not be the case for UK-spec cars. I have looked in the cubby hole on the left hand side of the boot and can't find any wiring (apparently that's where it's meant to be). However I have found the wiring for the microphone above the front interior cabin light. Can anyone verify whether UK cars are indeed pre-wired?
On a slightly seperate issue I have bought a Parrot MKi 9200 Bluetooth unit, which I will get fitted if the car isn't pre-wired. Has anyone using a Parrot got it to work succesfully with the steering wheel buttons?
GAH
Hi NealP,
Thanks for the reply.
I thought I would need some extra hardware for the Parrot to work with the steering wheel controls. I won't be trying to fit the Parrot myself though, I'll be getting a specialist to fit it for me.
Any thoughts on the pre-wired question?
GAH
Premium Member
Hi Guys,
GAH
I think the US cars do come with bluetooth prep as standard but Euro cars do not.
I tried a 9200 kit in mine and couldn't get it to work properly at all. I ended up changing the complete headunit for an Alpine with Bluetooth (Parrot based it seems) and iPod support. It all works as advertised although you need a small mountain of adaptors (loom, antenna, steering controls, parking radar). It sounds a lot better too.
Hi Huys,
Thanks for the replies.
@NealP, it does have a shark's fin antenna on the roof.
@thepurpleblob, you could be correct regards UK cars not being pre-wired, as I can't find the 54pin connector to attach to the ULF. The only cable and connector I can actually find is the one for the microphone. As for the Parrot, I already have the kit, and someone to fit it, so fingers crossed they can do it!
Regards,
GAH
Please let me know how you get on with the Parrot 9200 system, thinking of doing the same myself!
Recommended to me by Ray Smith as best option...
rgds
Michael
Hi Guys,
The installer turned up to fit my 9200 this morning, and he says the display unit is faulty! The guy is a professional Parrot installer, so I'm assuming he's correct, and I've arranged for a replacement which hopefully he'll fit next week. However, he did tell me that he won't be able to make it work with the BMW steering wheel controls, so I will need to use the Parrot controller, which I didn't really want to do.
Will let you know how I get on next week!
GAH
1 - 8 of 8 Posts
