2005 e61 5D95 ABS light
Tags
5d95 abs
1 reading
17K views 6 replies 4 participants last post by  Alan G
#1 ·
Hi, thanks for any help in advance. I have got the ABS, DTC, Handbrake light on constantly, have tried to clear the code 5D95 dtc control unit relay but it will not clear. I have replace battery and also tried another abs module but no joy. I have used inpa to expand on the codes and have got 5d95 low voltage at terminal 15.
I am really struggling with this.
thanks
#2 ·
This is usually either one of the wheel speed sensors has gone or potentially its a fault in the ABS controller. Since you've swapped the controller already its going to be one of the sensors. What are you using to read the codes? That error can simply mean your OBD cable isn't getting the correct signal on one of the pins.
#3 ·
I am using a laptop with inpa and also a scan gauge. The wheel sensors are all reading correctly on inpa and scan gauge. Maybe the abs unit I got is faulty. I really am a at a loss with it. Thank you for your reply.
This only happened when the battery run low as was working at the tailgate and didn't realise lights were on!
