bmw 318ci 2005 ,had car in bmw specialists today got fault where my petrol tank doesnt seem to be transfering petrol from one side of the tank to the other, car runs fine and no problem but i run out of petrol and gauge says i have a quater of a tank, garage says there is no vacume to fuel filter regulator and they have done everything but cant find the fault so 400 pound later ive got no where. please help realy tryin not to have to take it to bmw thanks
garage said they tried new pump but no change i looked in the tank when he showed me and all there is is like a sython pipe goes over the drive shaft inside the tank
Super Moderator
great indy BMW specialist i must say:sarcastic
its called a jet pump or syphon pump its job is to pump fuel bewtween the 2 halves it has no moving parts it works on the venturi suction effect, when it fails you run out of fuel with a quarter still showing on the gauge.ive seen it numerous times its in the tank on the passenger side with the level switch assembly, looks like a ball point pen on the drawing by the level switch..
http://forum.e46fanatics.com/showthread.php?t=715678
the hoses pop off it sometimes in the tank itself etc, yal have to pull it out and check the hosework to it..
thanks for reply, the bloke at the garage said that its only the 6 cylinders that have this pump and th m3s not my 318ci is this corrct?? thanks
