Hi, the drivers side window switch has stopped working along with both mirrors. All windows work fine when using their own switches, apart from D/S. Also no response to using the wing mirror adjuster. Any ideas?
Check the fuses, if not those then it could be a broken wire in the loom that goes into the door.
Could also be the switch unit.
I would take the switch pack out and check for power on the plug.
