I have recently bought a 2004 plate 645ci. I noticed that the rear speakers/ rear parking sensor bleeps were not working.
I took the car into my local BMW dealership and they advised that I needed a new amplifier as water had got into the amp area via a damaged seal on rear passenger light block. Given their projected cost, I thought I would look elsewhere (once I had picked myself off the floor)
Has anyone else had this issue before, any recommendations as to where I can buy a replacement Logic 7 amplifier and once bought is it easy to switch them over?
Any help or guidance would be gratefully received.
Thanks,
Richard
mate,
sorry to say it sounds like there spot on with the diagnosis. i had same thing on mine when i got it. the original bm salesman told me i just need to fade the idrive to the middle ???? surely i dont look that F*CKING stupid. :D
no need to answer that raffa
eventually got it sorted under auc... how long you had the car ? was it from bm garage??
probably could diy but if you got it from bm's ... take it back
keep in touch
Banned
This is a long shot, but it worked for me!
The drain hose on mine separated and flooded the amp completely - I too was told I needed a new one. Just for the hell of it (and let's face it, I couldn't screw it up any more), I removed the amp, split the case and painstakingly cleaned round each connector and the stuff on the PCB (transistors etc) - this was all 'furred up' where the water had been cooked. I used a soft toothbrush. I put it back together and it's worked fine ever since - gotta be worth a try vs £600 for new one?
Also if you bought this from a dealer within the last 6 months then they should fix this for free, regardless of whether or not it's a BM specialist / dealer. If it's a private sale then it would be more difficult. Have a look here:
http://www.bimmerforums.co.uk/forum/f22/buying-a-used-bmw-from-a-dealer-know-t60188/
Although if it was a private sale then I'd be inclined to follow Neals advice first, could save you a fair few ££'s
Good luck :thumbsup
