Over the last few months my car seems to have developped a tendancy to "stall".
When the engine is cold there is no problem
Once the engine warms up I have observed the following :-
Under idle conditions everything is OK - the engine idles very smoothly at 700 rpm
However when driving, the engine speed dips very low when changing gears - so to explain - I operate the clutch (manual box) and the engine speed drops of course. If I maintain the clutch depressed the engine speed will sometimes drop as low as 500 rpm before picking back up to 700.
Of course if I quicklly engage the next gear this is not a problem.
There are no other problems with the car. No lights, no codes and it runs really well.
Could this be an issue with a crankshaft position or camshaft position sensor for example ??
Any ideas you guys have will be very welcome
Digby
May be a problem with the clutch switch.
If you depress the clutch when standing do the revs go up.
I belive there maybe a software update for this fault.
Hi guys thanks for the ideas
The EGR valve was cleaned out just a few months ago so I dont think it is to blame
Need to do a check on the clutch although I dont remember noticing anything - I will confirm later today
So - it took a bit longer than planned but I checked out the effect of pressing the clutch in neutral
Basically no effect
With either a hot or cold engine pressing in the clutch changes nothing at all.
It seems the clutch switch works because the cruise control disengages with the slightest pressure on the clutch pedal.
Any other ideas ??
thanks
digby
