SOLVED!!!!
hello all..
my CD has jammed in the e46 04 satnav machine. does anyone know how to get it out.. every time i press eject the screen tilts to let the cd out but no cd comes out. then the screen stays on the lowered position and doesnt move back even if you turn the ignition off and on again..
the only way i can get it to reset is to pull the fuse and replace it when the system is on...
please help.
Solved!!!!
It didnt have a pin hole however if you have a look in the slot you see 2 white vertical bars. if you push these to the outside edges gently and at the same time then press eject, the cd pops out..
cheers for replying to the thread though!
Jay
