Hi there just looking through the posts for the problem i have but can't find my specific problem can you help,i have a 54 3 series with the sat nav that slides out to let me put a cd in ,the problem is it won't eject the cd thats in there the radio and cd changer work fine any ideas,thank you.
Any chance you could post a picture of the CD unit as Im not 100% sure I am thinking of the one you have.
However if its the BMW business CD/radio etc unit then this is a known method for retrieving CDs as they are known to eat them sometimes.
1/Press the CD eject button (igntion on obviously!)
Take a thin flat object like a lollipop stick for example!) and
2/insert it at a 45 degree angle into the CD slot, catch the edge of the CD and tweak it towards you.
It 'should' eject.
It may take a couple of tries as you need to press the eject button precisely just before you tweak the cd. If you dont care about the CD then you could use a small flat blad screwdriver.
Either way, if your car is no longer in warranty then you will need to buy a new unit if you want to use that CD player or I suppose you could jsut use the multichanger if it still works ok....
There is no permanent 'fix' that I am aware to repair the mechanism itself, however I do know of one electronics guru with a shop near me who would be the type to maybe repair it.
You may know someone similiar where you live, say an electronics or car audio specialist. WOuld be worth taking it in to see if they can repair it as BMW would just say 'replace unit' and the cost is a LOT iirc
