Hi
I have a this fault with my radio, when i start the car and switch the radio on it sounds like the aerial is not connected and i get a faint crackley reception. If i switch the ignition off and try again it comes on loud and clear (this sometimes takes 2-4 attempts).
Anyone know why this happens....is there something loose...or is it an electrical fault?
Have you had recent work done with the head unit or rear window? If not, then your diversity amp kept in the n/s c-pillar could be at fault.
Can you get at it, check the connections + if all OK remove the unit and get an expereinced leccy to look at the joints and see if there are any dry joints in it.
I have a similar problem with my 330ci but it is an older convertible so not sure if all the components are the same. Too frigging cold to look at it now!
