Hi, I have a persistent misfire on cylinder #4. I have pretty conclusively eliminated plug, coils, injectors, compression, or DISA as the cause. Spark plug tester indicates that there is no spark, but just on that one cylinder. 12v and ground to coil connector are good. I am not sure how to test the switching signal from the DME on the third wire, but assuming it is bad I opened up the DME in the vague but not too optimistic hope of spotting a problem. I have uploaded a photo of what I saw. I'm no micro-electronics expert, but it seems highly likely to me that the drooping transistor (if that is indeed what it is) on the left, 4th in a row of 6, is the cause.
Has anyone seen anything like this before? Can anyone tell me the specification of that component? Is it likely that is I simply replaced it it would fix the problem?
Any suggestions as to how to proceed would be most welcome. I would prefer not to have to shell out for t a new DME.
Many thanks in advance.
Justin
Vendor
I you can get the ecu to us we can repair or make you a new one
As we have been making and repairing bmw ecus for 20years
BW chiptune
Tuning BMWs since 1991
Dyno Dynamics rolling road.
BW autorepairs
Over 30 year repairing BMWs.
New and fully refurbished BMW/Alpina ,Ecus (DME,DDE)and Cas units.
BMW Ecu repairs.
Key data fixed for non starters or when theft attempted.
UK
0208 561 1818
07831 103030
Hayes
UB3 1BB
or
Spain
Orihuela Costa
+447831103030
