hi i was wondering if anyone could shed any light on this for me
my 325 sport has the yellow hand brake light and traction with abs on
at first i was told it was the clocks as the rev and temp gauge were bouncing around the place changed and programed in a new set no difference so i then changed the rear abs sensor and this made the lights go out until i hit 30 mph
then back on until i re started
all the whils the gearbox light is on and it seem to be in one gear all the time have pluged it in
i get no comms with auto box unit
no id
can bus shut down
in the instument cluster
aborted egs control of auto box
no coms with instrument module
in athe abs and dsc section
can abs dsc signal
can timeout dme dde not present
atf temp
inthe gearbox section
cam sensor in the engin section
have had steering wheel sensor and wheel speed sensors show up too
i know this is a little vague
but im really in the dark on this now
just looking for a pointer in the right direction
thanks lawrenze
no id
can bus shut down
can abs dsc signal
atf temp
thanks lawrenze
