Hi all
In the past two months I've noticed that I'm getting static on my radio when the air con fan is on (the air con itself doesn't need to be switched on). It seems to be more prevalent on certain stations and in certain locations the radio is completely drowned out.
What could be causing this and any ideas on how to fix it?
Tyrone
try checking the connections on the back of your a/c pannel, lose or poor connections will cause interfernace,
also check how well your ariel is attached, if its lose on the body/ has a bad connection to ground/ or is not conected to the radio very well
one last thing, have you had anything done to the car recently? in the last two months,
Sam
Hi Sam
Don't have an aerial...? Well not one that I can see anyway!
Nothing done to the car recently.
TN
