boot lock works then doesnt work 1st stopped on a frosty morning in december then last week but opened today, its a pain in the behind, now wiper has stopped working and heated screen is performing on a low power by the looks of the screen when its on, any one help??cheers
Sounds like you may have a problem with the wiring that passes from the car onto the bootlid/hatch. Check under the rubber gaiter for damaged wires.
You've memorised it too:hihi
This is a very common fault and like Red has mentioned, the first place to check:thumbsup
You should also remove the trim panel from the boot as they are common for getting water ingress into the boot and it ruins the motor and other items :frown
Never steam clean around the rear wiper on a touring e46! :frown....................:mad
