1 - 20 of 22 Posts
Hello everybody,
I have just replaced my front components in my 2004 E46 convertable with a set of vehical specific Rainbow IQ265.25
These really do sound good and was soo easy to swap for the stock BMW components
Im gonna write up a quick guide of how i done it :)
He is a quick comparrison of new and old woofer and tweeter
So firstly i started by removing the door cards, this was relativly easy there are 5 torq screws holding the door cards in place the loacations are circled and arrowed below,
The airbag badge leavers out with a screwdriver and the cover behind the door handel pops out with a small screwdriver
Once all 5 screws are out you need to removel the black plastic cover where the wing mirrors are, get your fingers under the front closest to the window and pull towards you, once it has popped foward it needs to go up to come free.
The door pannel is clipped in place with many plastic clips, start on the top fron corner and pull the door card away from the door the clips will crack as they come off. Move around the door once they are all poped free the door card will come off in your hand.
On the driverside you need to dissconnect the wingmirror switch. use a pair of long nossed plairs and the plug connector apart
On both sides the door handel needs to be dissconected, it just pulls foward and out and the speaker wire needs to be dissconnected its connected directly into the back of the woofer pinch the clip together and its apart.
Now you have the door cards lose, you can remove the BMW speakers
The wooofer is held in with 3 philps screws and the tweet is held in place by three torqs screws
I used dynamat sound profing on the door card around where the speakers are mounted
Because i used direct replacments they fitted where the stock speakers came from with no adapter plates and no modification to the door card, so they screwed back into place with the original screws
i wired the tweeter and the woffer together through the crossover and taped all the wiring down,
Next i could replace the door cards, i replaced any broken clips that i had broken during removal (you can buy them on ebay)
And re-wired the speakers to the exsiting wiring for now, im gonna amp them soon
Dont forget to plug your mirror cable in
The door card should press back into place with all the clips clipping back into possition. Do the torq screws back up and replac the airbag badge and your all done
Uber Platinum BFuk Member
Nice "How to" Sam :thumbsup
Question : Whats the depth of the original speakers and how deep into the door can you go with aftermarket speakers ?
Thanks.
Thanks.
I was told the mounting depth of about 61mm! You can buy mounting kits which give you a few extra mm to fit some after market speakers. Hope this helps :)
That's handy as ive got some FLI speakers with a depth of 55mm, that saves me getting the lump hammer out :silly
Top lad! Your my hero for practically telling me how to install my sound!! haha! Cheers fella!
lol thought you would like it :)
Thanks.
thanks mate,
i put them in the loft last night lol i will jump up there tonight after work and have a quick measure,
i didnt really look at if you could go inside the door but it didnt appear like you could, the speakers are mounted into the door card and sit flush with it. so they dont pretrude within the door at all
the speakers are mounted on to a rim that sticks up by about 1 inch so if you use a dremel or something you could nibble it out and give yourself that extra inch
hope it helps mate
Thanks.
Sorry for late reply ive been fitting my angel eyes lol
From bottom of magnet to top of mouting plate they are exactly 2''
so not alot of room mate
Rainbow UK Stockists
Hi,
Im currently looking round for stockists of the Rainbow IQ265.25-BMW3sCoupe-231588 IQ Line Car Speakers - Im only finding Ray Smith @ £249.99.
Does anyone know of any other stockists or prices? Any recomendations?
I want to give the install on the fronts a go....
Also - What do you do about the rears? Or are you just leaving them as is with the upgraded fronts & sub??
Many Thanks
Great guide Sam, thanks! How do your Rainbows sound? I am desperate for some more mid-range and a little bit more bass. I intend to put a speaker level Amp and Sub in eventually but both of my rear speakers have packed up at the moment which I think is down to an OEM Amp fault so I need to sort that out first.
Discussion Starter #12
the rainbows sound very good,
i ahve recently amped them so they sound even better now :)
the bass is good, the mid range sounds amazing, i also have a sub in the ski hatch which sounds goood too,
the oem amps are known to go, there are a few threads on here about it :(
hi what amp did you use??
im thining of going down this route,but also replacing the rear`s(unsure what with yet)
cheers
I have exactly the same car as you that I bought recently and I love everything about it except for the poor sound quality.
I found these speakers but my question is (since im quite a noob at this), will I be able to place these and replace the front speakers without drilling holes and all that stuff AND can I also place these in the back (same ones) or do I need other types of speakers for the rear. If so, can you recommend me a good brand and not so expensive speaker?
Alpine SPG-13C2
http://www.dynamicsounds.co.uk/alpin...w-p-23594.html
Or these ones which are 6.5 inch (17 cm) and use a 165mm speaker adapter kit?
Alpine SXE-1750S Component Speakers (17cm, 280w)
http://www.amazon.co.uk/Alpine-SXE-1750S-Component-Speakers-17cm/dp/B0000WS0MS
Adapter kit
http://www.caraudiodirect.co.uk/product_info.php?products_id=7640
Thanks a lot!
this is the dilemma im thinking about
do i spend 154 for front rainbows or would other makes sound just the same and i can save money??
Has anyone managed to find any other speakers that are a direct replacement?
Or found the Rainbow IQ265.25 any cheaper than £250?
1 - 20 of 22 Posts
