Car runs fine but occasionally 'telltale' warning light and amber brake warning light come on together and a tone sounds. Both stay on until engine is switched off for a while and then clears. Had fault codes read and it is clear, had brakes checked and they are fine, no issues. Any ideas? Thanks.
Usually the Steering Angle sensor. Does the steering wheel sit straight when you are driving straight? Is the car pulling to one side when driving straight.
Also who read the fault codes? Often they will only read engine fault codes, and not the ABS, traction control or other system fault codes.
