Hi,
I've had some intermittent wiper problems for a while with my 2003 E60 530d, now they will not complete a cycle in any setting (stick in vertical) with a buzzing noise from the motor assembly and the linkages all seem free moving. I tried the relay just in case but still the same.
I found a used linkage/motor from a breaker but it seems impossible to access the 5th bolt which is the second from the left which is located under the central roll bar anchor right by the bulkhead. Basically I cannot remove the defective assembly.
Has anyone attempted this DIY? And if so please point me in the right direction.
