The aircon blower remains on after the engine is switched off. None of the instruments on the aircon panel operate but the display still shows the temperature reading. If the blower fuse is removed it turns off but the display is still on. How do I get the fan and display to work properly?
You should first get the fault codes read for the heater system, it may be something as simple as a relay or it could actually be the control panel, :frown. A BMW main dealer or good BMW specialist will be able to do this for you.
