1 - 10 of 10 Posts
Just got delivery of my swirl flap blanks, and a vortex filter for my 330d. But i was wondering is there anything else i should do to keep problems at bay?
Also is it possible that a turbo can wreck these engines? How can i prevent it?
Help greatly appreciated, thanks.
You should clean out the EGR valve as well, as for the turbo, not a lot you can do, all turbos wear out eventually, they aren't known to break up badly so you should be fine.
HUGHES330D, is your car the 186 or the 204 model(manual)?, because the 186 manual has no swirl flaps as i have just found out from reading the info here on the forum.
Cheers.
I know this is stupid but where is the EGR unit and how do you clean it?
1 - 10 of 10 Posts
