Hi
The outside mirrors on my 2003 325ci sport have stopped working. The motors still work as the near side mirror moves when in reverse and the switch is fine in he drivers door but the mirrors will not operate manually or with the memory button on the seat. Have checked the fuses too. Has anyone got any ideas?
I have had the door panel off and checked connections and tested my control unit in a different car and it works perfectly so I think that can be ruled out. I found another article on the web describing a similar fault and the answer came back that it was a coding error (???).
Today 06:57
NealP I've had this question asked before. It is the memory module for the seats and mirrors that could be at fault.
Will get the memory module checked as you say.........cheers.
