Hi,
Just bought an '03 320i Touring, got a few issues, so was wondering if anyone could help me with some simple fixes.
Issues:
-Rear heated window not working (suspect break in circuit caused by the rubber seal)
-Remote keys dont work, keys still sending signal, they worked when i took it out for a test drive 6 weeks ago. (Have tried reprogramming, no other locking issues, so suspect possible fault in FZV?)
-Headlight washers leaking, is their an easy fix? (currently disconnected and blocked the pump outlet to prevent further leaking)
-Rear parking sensors seem a little hit and miss
Thanks in advance for the help:thumbsup
The heated rear screen problem could also be a broken wire where the wiring goes from the tailgate to the car.
Parking sensors can be monitored on a scanner under the live data, any BMW independent specialist will be able to do this for you. :)
Thanks for the speedy replies, i will definatly be giving the washer guide a go.
On a side note, i had 4 bridgestones fitted today, feels 100x better to drive (no more scary moments going thru puddles!)
EDIT: also got the alignment done, and after an extended drive the steering wheel is now wonky, is this just a poor alignment job or is there a bigger issue?
