My bmw seems to be loosing power when i change from one gear to the next then suddenly pick up and shoots up,i have the code read today using autologic scanner which reads central body electronics 5 faults, instrument cluster 1 fault, multiple restrain 1 fault. as far as i know all my electronics are in working order. any idea what might be wrong
The codes was read using a autologic scanner which i was told dont give codes it just tell you what is wrong which i listed above
When you read the codes using the Autologic it will give the code numbers, I've used one myself a few times.
To give a example.........
central body electronics 5 faults. :confused
Lets put it easy. :hihi
5 football teams won last week, who were they :hihi
unless we have the code numbers with explanations we are stuck :thumbsup
The body control module cover alot of items :thumbsup
