That would be the front wishbone rear mounting bush. They are a weak point on the E46's but you really need to get it checked before you plough any money in to it.not sure what bushing, someone just suggested it. The Problem is when driving you sometimes feel the steering make a sudden pull to one side.
That's a very constructive reply mate :thumbsup.That would be the front wishbone rear mounting bush. They are a weak point on the E46's but you really need to get it checked before you plough any money in to it.
My E46 did the same, changed bushes- still same.
ended up replacing the whole wishbones and roll bar links to cure it.
Get it checked first.
I would have expected something like this from you
'If your car feels like it's had a few too many puffs on the ganja, wacky backy...then you need the lower testicle joints changing' :rofl
ok thanks, will check it out first. Another question is when you read your ECU if there is a problem with your air intake sensor, will that show in the reading
yes--a code will appearu have to find out what it is .
Yeah the car seems to pull back sometimes as if it want to stall, especially when going slow. I had the codes read but never come up with nothing
how do i do that and where is it located?
can anyone tell me if the MAF sensor is a little black hose connected to airbox hose or is it a clip on thing with some wires on it like yellow, black etc clip on to the airbox hose
