Hi,
I've just recently purchased a new 2011 DVD for the sat nav in my 530d. Everything worked fine for a couple of weeks but recently it began to lose the mapping and now it refuses to bring up any maps at all. The GPS part is still working as I continue to see the co-ordinates and altitude but the map screen has disappeared. Has anyone had this problem or do you have any suggestions on what might be causing the problem. I have removed and reloaded the disc but this didn't make any difference.
Thanks,
Ken.
Could be a failing DVD laser. Try a CD based map. If that is your problem the replacement DVD drive mechanism is about £90.
