Today when I started my car after finishing work right after few minutes I got a warning on the dash STOP ENGINE OIL PRESSURE....
What does this mean?
I switched the engine off then I started the car again after few minutes then it was fine the warning did not came up at all what was that???
What does that mean.....??????
No or very low Oil pressure is bad, you should indeed stop the engine and check your oil level, if it is low then leave the car and go get some oil, driving the car with no oil pressure will kill the engine.
If the oil level is OK then you should get the car recovered to a BMW specialists or good independents and have them check the engine over, hopefully it will be something simple, like a oil pressure switch failure. But you may well need to have the oil pressure checked and then have further remedial work performed.
