1 - 10 of 10 Posts
Hi, recently brought 2003 525i sport, on the test drive, driving it home and few spins here and there nothing. But yesterday the light came on and went into limp mode. I turned it off and waited and its gone seems to be fine. What could it be? Car only has 71k and serviced insp2 at 68k should i be concerned and shall i get the codes read.
Hi, I would get it checked out by a automatic gearbox company as mine is in having an expensive gearbox recondition. Mine is slipping into failsafe mode when it changes from first to second. If your lucky a gearbox oil and filter change may help. Hope your not to late, as I was.
Dam sorry to hear about that cabdriver, Hinesh i agree with cabdriver , take it to a bmw specialist and get the codes read and see whats wrong, if its somethign major which i hope its not, i would get bmw themselves to fix it. But it could be what cabdriver said new gearbox oil, maybe urs had dodgy oil in it.Im not too sure but good luck
Get it to an autobox specialist asap - you may be lucky enough to get away with a service - if the light has come on then something is definately gone wrong - any autobox that goes into limp mode does so because it is a failsafe system to get you to a garage and save further possible damage to the gearbox.
Hello - I am new to the forum, having had two BMW's in the past 3 years & thought it was well worth joining. Currently I have a 525 Sport Auto E39 (Jan2003) I presume simaler to Hinesh's - mine has 55k miles on the clock and I am very sad to say it has been an absolute nightmare :frown. I bought in in August 08 and so far it's had:
Service 2
Brand New Brakes rear & front
Refurbed alloys with 2 new Michelen tyres (£250+£250 ouch)
New engine (last one blew up with 3 cyclinders & pistons frying while I was doing 60mph down the motorway)
Associated : new engine sensor, new radiator, new thermo, new maf sensor, waterpump
Finally : recon gearbox!
The point of note is the gearbox, the first gearbox would go into safe mode (a clunk then it will stay in one gear I presume third?) every so often when I was doing stop start driving. I really hoped with the new recon box this problem would stop ........ but alas it hasn't. Now reading up on the transfail safe program which I presume this is, I have seen all sorts of posts from gearbox sensors, wheel sensors, alternators, maf sensors, tranny oil changes, and of course tranny replacement needed. I have done all the expensive parts as above and am wondering what else it could be as it only happens during stop start driving (normal urban driving) rather than on a motorway. Any help would be much appreciated as the guy who rebuilt the gearbox has had it back 4 times in the last 1.5 months for more than a week at a time and it is beginning to do my head in. :mad
Service 2
Your auto box has a dedicated diagnostic port on it. Best thing to do is get the codes read from it which will tell you why it went into limp mode.
Thanks Neal - it's going back to the gearbox chap after the bank holiday ..... will ensure he hooks it up to the diagnostics machine.
Just an update - gearbox fella has read codes which say there is a misfire in the engine which is causing it to go into limp mode. He is taking it to a BM specialist in Hitchin ........ my trials continue !:confused
1 - 10 of 10 Posts
