OK I am getting desperate. My 2002 BMW 330D (184 BHP) auto has developed a mysterious, fairly heavy vibration - but only between 2000 and 2200 rpm in top gear. It is most likely to occur when the engine is under load, such as climbing a hill. We are talking fairly loud, "feel it through the floor and through the seats" vibration here, not just a rattle. Unfortunately this rev range works out at exactly 68-72 mph, which is just exactly wrong for motorway work (I normally drive a bit quicker if I can, but often the other traffic means 70 can't be avoided). The problem never occurs at speeds below 70 in normal mode on the auto box (not even in the same 2000-2200 rev range in a lower gear). The problem disapppears completely above 2200rpm or 75mph+. If I knock it into "sport" mode, which changes the rev range through the gears, the problem immediately disappears. However, I can occasionally reproduce the problem in "sport" mode at a lower speed (60mph or so) in a similar rev range but it is less likely to occur. I changed the tyres recently - made no difference.
I have taken it to a BMW garage who couldn't identify anything wrong at all. I then took it to an idependent BMW specialist who road tested it up to 70mph and managed to reproduce the problem. Their mechanics agreed that there was clearly something not right so they kept it for 2 days and tried everything - but still couldn't work out what the problems is! It has had the propshaft center bearing replaced and the rubber "doughnut" that links two sections of the propshaft renewed - but the problem persists. They have checked engine and gearbox mountings, rear susupension bushes, tried it with different wheels etc.etc. etc. One of their mechanics has 20 years experience with BMWs and says he has never encountered a problem like it.
Anyone got ANY ideas? Anyone know of BMW version of House who can diagnose weird problems?
